Results 1 to 16 of 16
Thread: No start after tune load
    Tuner in Training wesp89's Avatar
    May 2019
    Georgia
    41
    I returned my car back to stock with my sct live wire ts today and loaded a new tune through hp tuners after loading the tune I fired the car up and let it idle all the way up to running temp while data logging it everything seemed fine so I cut the car off and went in the house for about 30 mins and decided I would take the car for a drive went out got in the car and turned the ignition and nothing happened car didnt even turn over so i went back in the house and grabbed the laptop to review the tune when I got back in the car I decided to give it one more try before connecting the lap top and the car started normal so I cut the car off and started it back no problem took the car out for a spin came back home and parked it for about a hour tried to start it again and it wouldnt do anything and from there I loaded a tune back in the car with sct live wire and the car has been cranking fine so with that being said what am I doing wrong I made sure the battery in the car has a good charge no problems there and ever time I plug the laptop to the car its plugged in to household power with drop cord
    May 2019
    Georgia
    41
    would this problem come from me reading in the tune that was in the car (probably a SCT tune) modifying it and flashing it back in?
    Mar 2010
    New Orleans, LA
    630
    no what u describe needs more investigating
    cant fix the problem until u identify the cause
    May 2019
    Georgia
    41
    So where should I be looking
    Apr 2018
    605
    Why don't you check the OS ID of what you think is the 'stock' tune to be sure it's stock. While you're at it see if you can find one in the repository and do a compare. Make sure something isn't off or weird.
    Knock Retard is the reduction or prevention of knock by lowering ignition timing:
    (+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
    (--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
    __________________________________________________ ________
    2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
    Don't fix it if it ain't broken | Maximum effort gets maximum results
    May 2019
    Georgia
    41
    When I load my stock tune into hp tuners the os is blank
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,262
    any dtc's? Doesn't sound like a tune issue to me, rather an ecm or wiring issue of some sort if it starts sometimes but not others.
    May 2019
    Georgia
    41
    After I loaded my old tune back into the car with my sct live wire all the issues went away so if it was wiring / ecm wouldn?t the problem still hang around no matter the tune? I?m going to load the tune into the car again with hpt this afternoon to see if it happens again
    May 2019
    Georgia
    41
    No on the dtc?s also
    May 2019
    Georgia
    41
    And I forgot to mention the car has been driven few thousand miles sense the work has been done and tuned just bought hp tuners to adjust some issues like leaning out on idle , and hanging rpm in between shifts
    Apr 2018
    605
    Quote Originally Posted by wesp89 View Post
    Are you looking in the right place? CTRL+D , Controllers Tab?
    That's very suspect to me that OSID is blank but what do I know... Maybe that 'stock' tune isn't really stock. It could even be the SCT boxed tune. Did you compare like I mentioned?
    May 2019
    Georgia
    41
    ok I was just looking under the os tab by "engine" im brand new to this so bare with me I did CTRL+D and the info on both tunes (stock/and the one I pulled) have the same info
    May 2019
    Georgia
    41
    Loaded the tune back in the car today with hp tuners and all is well so far starts every time
    HP Tuners Support
    (foff667)
    28,262
    Which is why I suspect a wiring or internal ecm issue of some sort.
    May 2019
    Georgia
    41
    If I remember correctly I don?t think I turned the key off after loading the tune the first time I just started the car after the write more then likely it was a error I made it it does it in the future I?ll repost
    Oct 2019
    40
    if the car is up to 10 years old. then unplug pats.
