Results 1 to 5 of 5
Thread: MAF Logging?
    Jan 2019
    21
    MAF Logging?
    I need some help that I can seem to figure out.
    On MAF tuning it uses Period m/s, where am I able to log this? I was using BYT's layout, but looking at the MAF 1/2 tables there, it only fills in the very first block.
    Senior Tuner BackyardTurbo_FTW's Avatar
    Jul 2009
    East Suckburg, PA
    1,163
    Make sure you are logging MAF Sensor period 1 and 2 in your channels list. Also, check the graph properties and make sure the settings match this screenshot
    Jan 2019
    21
    Roger that, will give it a go.
    My trims at idle are skyhigh, like in the 25-30's, but cruising it's perfectly fine +/- 5.
    I had to scale the IPM table down a little bit for the larger injectors, the limit of it seems to be about .9. So a little bit of MAF tuning at idle, and we should be good to go hopefully
    Jul 2009
    East Suckburg, PA
    1,163
    Just watch because some of the idle cells are - values and won't adjust correctly doing copy/paste special from the chart in the logger. It will end up moving the value in the wrong direction!
    Jun 2018
    43
    So how do you treat the (-) value? Manual multiplication at each cell?
