Working on a flex fuel upgrade for a pretty much stock LT1 Camaro SS. Car ran fine and as soon as I put E85 in it (30% right now) the car dies as idle given enough time. You can here it when it's ready to die and the scanner shows it spikes the timing from 12-13 to 20+ and then crashes to 1-2 sometimes negatives. It'll do it a few times and then die. It's almost like dealing with a cam. Any ideas? I though it might be the alcohol adder table but I zeroed it out and it still does it. Not sure what the cause is but the car runs fine other then that.
