Results 1 to 10 of 10
Thread: How are you bleeding these whipples?
    Baltimore, Md
    1,208
    Trying to get what i believe is air out of a Jeep we keep seeing 150 degree intake air temps while cruising down the road on 80 degree day. Tried getting front up high, back up high, pulling vacuum on it, pinching return line shut to force air through core under pressure every trick in the book Ive ever used
    Factory Stock 97 SS M6 13.51 @ 104.3 mph
    Stock Longblock LS1 w/ 233/238 P.S.I. Cam
    10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
    '99 TA trunk mounted 76mm 6 Liter
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    32psi and still winding out 5th on the highway somewhere
    May 2016
    1,134
    Make sure the bypass valve is working. Might be good on fluid but bad bypass valve
    Baltimore, Md
    1,208
    Whats best way to make sure its working 100%? I have a setting fixture for the LS LT cars.
    Its a whipple car, I have IAT Source set to IAT that is correct not on Manifold Temp (thats a calculated value right) Temp raises up soon as I LIFT which seems kinda odd
    Feb 2016
    431
    Temp goes up when you lift as you are now bypassing intercooler
    Baltimore, Md
    1,208
    Just not used seeing IAT react that quick to that!
    My wifes Whipple 392 Charger seems to typically run around 60 degrees hotter than ambient air. That's on the highway. To me that's kind of dumb but the Whipple and their supplied heat exchangers are just not very efficient. My old Edelbrock 392 Challenger would run about 25 above ambient.
    Feb 2016
    431
    On the highway the whipples are bypassing the intercooler (whereas the edelbrock does not) but even so I generally see around 20-25c above ambient.
    As soon as you step on it the temp should go down
    Jul 2015
    925
    Quote Originally Posted by Hemituna View Post
    I did not know this. How does it bypass and how does it know when to switch?
    Thanks for the info.
    Feb 2019
    Owensboro, KY
    266
    Mine runs between 30-40* hotter than ambient and goes down once you go into WOT But i do have the upgraded stage 2 kit. If you find a better way to lose some of that heat let us know. Im thinking about running a meth kit just for this reason. I also dont remember installing any kind of bypass valve into the inter cooling side of mine..??? Anyone else heard of this? Also i have been told the edelbrock kits were worse with this than the Whipple but thats all hearsay..
    Feb 2019
    Owensboro, KY
    266
    Also Jay i run a few bottles of water wetter from local parts store to help with the heat.. Just my .02
