I am trying to add the correct Deka 80lb data and I am at this spot. "Fuel to Wall Transient" I cannot find where I should add this.
Heres the data. It's near the bottom. Anyone know where to input this??
Siemens Deka 80lbs Injector Data (1).xlsx
fuel >> transient >> Transient fuel mass gain >> Fuel to wall impact factor
fuel >> transient >> Transient fuel qualifications >> min fuel milligrams
Are you in advanced view?
Can you post your tube file so we can see what your seeing?
[ECM] 12283 - Fuel To Wall Impact Factor vs. Cool Temp vs. MAP:
I think its what your looking for..
Your not seeing it because its not there , looks like its not supported on that OS..
I figured. When I click on OS nothing shows up thought so I couldn't check it. Thanks for the help.
