Results 1 to 7 of 7
Thread: while pressing the brake pedal it wont accelerate
    Jan 2008
    45
    Hello everyone, been looking around and had no luck trying to figure out why my LS3 swapped S10 Blazer won't accelerate when I'm pressing the brake pedal, if I don't press the brake pedal it accelerates. It really sucks because my blazer is 6 speed manual and when I need to take off on a hill its a beach. It'll roll back til the gas pedal activates again after letting go the brake pedal. What can it be? I'm burning the clutch. You know how usually you feather the gas pedal a little while pressing the brake on a hill but I can't do that. If I'm pressing on the brake the gas pedal does not respond. SMH
    1999 S10 Blazer
    6.2L LS3
    T-56
    TBSS ECM
    Current Performance Engine harness
    DBW.
    1999 Chevy S10 Blazer 4dr w/2008 LS3 Corvette 6.2L mated to a t56.
    Nov 2009
    All Around
    3,149
    post your tune
    Jan 2008
    45
    1999 S10 Blazer TBSS tune 6 10 19.hpt heres my current tune.
    Jan 2008
    45
    Quote Originally Posted by SultanHassanMasTuning View Post
    post your tune
    Jan 2008
    45
    Trouble Codes:
    P0122 - Throttle/Pedal Position Sensor A Circuit Low (Pending, Current)
    P0223 - Throttle/Pedal Position Sensor/Switch B Circuit High (Pending, Current)
    P0315 - Crankshaft Position System Variation Not Learned (Pending, Current)
    P0449 - Evaporative Emission System Vent Control Circuit Intermittent (Pending, Current)
    P0606 - ECM / PCM Processor (Pending, Current)
    P2122 (Pending, Current)
    P2127 (Pending, Current)
    P0230 - Fuel Pump Primary Circuit (Pending)
    P0443 - Evaporative Emission System Purge Control Valve Circuit (Pending)
    P0452 - Evaporative Emission System Pressure Sensor/Switch Low (Pending)
    P0463 - Fuel Level Sensor A Circuit High (Pending)
    Controller Type ID By OS: 5040
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    That p0606 is usually from modifying the throttle body settings too aggressively. Also looks like you have throttle body/accelerator pedal issues. Im assuming a swapped vehicle. Double check all connections.
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Nov 2009
    All Around
    3,149
    nothing wrong in the tune, but as you just posted could be related to all those error for the throttle actuator
