I am trying to get an ly6 with a BTR stg 4 turbo cam, Bosh 210 injectors, and a turbo to start. This is a swap, the donor was a 2008 2500. I also have a t56 behind it.
I have started the motor with the cold side unhooked from the intake. Seemed to idle alright (telling me that I have gotten halfway close on scaling hopefully). The issue came after I hooked up the cold side. I was able to get it to start by hitting the throttle but it didn't want to idle. The log looks weird to me because one bank stays flat and the other seems to go rich?
I have tried messing with the ve tables (also put the original scaled tune that doesn't have the 2 bar os) I am either way off or there is another issue because taking them up or down doesn't change anything. Not sure what I am doing wrong or what direction I need to go in. Thanks in advance.
first_startup.hpl
Turbo_LY6_scaled_maffail_spark reduced_2barSD.hpt
