Thread: Turbo E38 startup issues
    May 2019
    4
    I am trying to get an ly6 with a BTR stg 4 turbo cam, Bosh 210 injectors, and a turbo to start. This is a swap, the donor was a 2008 2500. I also have a t56 behind it.
    I have started the motor with the cold side unhooked from the intake. Seemed to idle alright (telling me that I have gotten halfway close on scaling hopefully). The issue came after I hooked up the cold side. I was able to get it to start by hitting the throttle but it didn't want to idle. The log looks weird to me because one bank stays flat and the other seems to go rich?
    I have tried messing with the ve tables (also put the original scaled tune that doesn't have the 2 bar os) I am either way off or there is another issue because taking them up or down doesn't change anything. Not sure what I am doing wrong or what direction I need to go in. Thanks in advance.
    first_startup.hpl
    Turbo_LY6_scaled_maffail_spark reduced_2barSD.hpt
    13,574
    What map sensor is it running?
    The KOEO is at 103kpa, though it may be higher because it's still logging the 1 bar MAP channel. It seems the linear and offset data is incorrect for the sensor right now.
    May 2019
    4
    It is a 3 bar map from efisource
    May 2019
    4
    I looked through the channels available to log and the one that is in the log was the only one I found.
    I put the stock settings back in for the map and plugged the stock map in the harness to see what it was reading and it showed 97 kpa. To get the three bar to read the same I had to adjust my offset to 4.9 instead of 10.33.
