Results 1 to 3 of 3
Thread: Urgent Speed Limiter Help!
    Dec 2017
    20
    I'm putting the car on the dyno tomorrow and need to raise the speed limiter so i can do the pulls in 5th. Its a 2017 Mustang GT Manual. Its running a 3.55 rear end so i know it will hit the speed limiter before the rev limiter in 5th.
    Is it as simple as going in to SPEEDO > LIMITER > VSS LIMIT ETC and raising it to 255mph, or do i also need to fiddle with the MAXIMUM SPEED tab below it and change the speeds in there?
    I tried changing the values but it prompts me with a warning about the value being outside the max/min and that it can put my module in an unrecoverable state. Just want to be sure before i screw something up!
    Any help please?!?! Thanks!
    Nov 2009
    Jeddah, Saudi Arabia
    2,094
    on the newer ford PCM there is 2 tables VSS limit ETC stock is usually 155 raise to 210 you will also have a table under it that has the same speed limit high light all and raise to 210
    E-tuning/remote Tuning Sultan@mastuning.net Follow @MASTUNING Contact/Whatsapp +966555366161
    [URL="http://www.mastuningsaudi.com"]
    Dec 2017
    20
    Awesome!! Thanks!!!
