Brand new to HP tuners (former Jet user, huge difference )
This was a 1997 K3500 with a diesel and a 4L80e transmission, not sure of which transfer case as it only had the transmission in the back when I bought it. The engine I am using I am told is a 2003 5.3, it came with a drive by cable setup, and the truck amazingly had a drive by cable throttle. I have removed the gas pedal and the throttle body and replaced both with normal cable run. The original computer (LS that came with the harness) wouldn't let it rev, only idle so I have replaced that with a 1999 silverado ecm. I assumed that the original trans from the donor engine had a 4L60e transmission so I've done the removal of the white wire from S and moved the brown wire from U change on the trans plug. I then added to the red connector pins 22 and 23 for the Speed sensor. still nothing. My 4L80e is not the original, the one I have has the cooling line separated by a good deal of space so I am told it a later one (can you tell by a number some place the exact year?
when I do a swap like this I leave the original wiring harness in place and use 3M connectors to connect the LS sensors to the instrument panel gauges.
if I use the connector from the diesel engine and ecm it will shift 1st to 2nd or maybe it's 1st to 3rd). Right now I have the Diesel ecm off and the LS connector is what is in the trans.
My hp tuners software is 4.4.4 so I didn't do a segment swap for the transmission because it is select able in that version.
With the changes I've done, the speedometer works, has worked really for a while if I use the front speed sensor, the trans is in 2nd I believe and that's all it ever does. The tach and fuel gauge also are not functional. when applying throttle it falters a little until it clears then it seems okay, but not perfect. Right now just trying to get it shifting before I worry about the tune for the engine.
HELP!
thanks in advance!
Robert
