Is it possible to OS swap on 2011-14 29Bit GPEC2 PMCs . For instance swapping a 6.4 calalabration into a PCM with a 5.7 calibrabraion. Looks like both PCMs are the same Part Number f
Only in a few instances when the base part number are the same for both ECUs.
It's very easy to brick a dodge ECU if you flash a file that doesn't belong there.
9 sec Montecarlo SS
