Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Thread: Fuel Trim Basics
    Quote Originally Posted by 123pugsy View Post
    OK, I made some adjustments to the VE table twice.
    On the left of the pics is just disabling everything for the logging, the middle is the first adjustment and the right is the second adjustment.
    How close do the numbers need to be?
    Do I use the average as my guideline? Or the plus or the minus?
    Thanks.
    Assuming you drove around for a good while to get those numbers the fueling looks alright ish, needs less fuel at idle more everywhere else it seems. Everytime you make a VE adjustment you should be resetting your LTFTs in the scanner so it doesn't skew the data. If you put bad data in you'll get bad data out.
    A lot of this is trial and error at first but you're on the right track.
    Jun 2011
    MARKHAM,ON
    77
    Quote Originally Posted by 3strokeEngine View Post
    Thanks.
    Each run was 16 minutes and change, engine warmed up well.
    Tables were empty each run and repopulated as I drove.
    Jun 2011
    MARKHAM,ON
    77
    You then log LTFT in the scanner histogram with a layout that matches your VE table so you can copy you LTFT errors and paste into your VE table by right click -> paste special -> multiply by percent half.
    Damn....I read this and was trying to change all the numbers manually by 1/2%. Didn't read carefully as I was still in the flustrated learning and nervous state. Feeling better about things now.
    The paste special cut and paste works real easy.
    So, I imagine there will never come a time when LTFT's will be at zero average when scanning.
    Is it the average errors I'm supposed to copy/paste?
    When to stop this and do the next step?
    What is the next step?
    Thanks.
    Dec 2008
    Nevada
    4,452
    the environment is constantly changing. given this fact, use the copy paste method until your error values being recorded are within +/- 5% of 0.
    you should be monitoring average values when performing these steps. make sure you smooth your changes using the editor table smooth functions.
    you can feed in some ignition after working the fuel tables into a desired level of error. motors close to stock typically dont need much more than the oem ignition map on standard pup gas. these motors have fast burn head chambers so ignition around 19-23* is pretty common depending on engine behavior and installed components.
    this assumes the motor in question is N/A.
    Jun 2011
    MARKHAM,ON
    77
    Quote Originally Posted by cobaltssoverbooster View Post
    Thanks.
    I'll tweak it a bit more and call it good.
  6. #26
    Dec 2018
    Ontario, Canada
    11
    How does one reset the LTFTs?
  7. #27
    Jun 2011
    MARKHAM,ON
    77
    Quote Originally Posted by carzan View Post
    They don't actually reset. They are constantly running to give fueling info.
    To clear them from your scanner, just click Log File > Close Log File > Start Scanning
    I usually close the scanner and restart it.
  8. #28
    The LTFTs DO reset and you MUST reset them everytime you flash a change to your VE table or it will skew your data and youll be chasing your tail. The goal here is to try to get your fuel trims +/- 2%
    Open your scanner and start scanning and look for the little green power button on the top of the scanner. Click that and it brings you into the scanner bidirectional controls.
    Navigate to engine -> fuel then click "LTFT Reset".
    On a side note LTFT works for doing these adjustments but it takes a long time for your LTFTs to average out once you reset them. I prefer logging LTFT + STFT as it seems to populate with accurate data much quicker than waiting on the LTFTs. Of course a wide band O2 is the best way to go about doing this but you can get danm close with narrowbands if you can spot trends and adjust accordingly
  9. #29
    Jun 2011
    MARKHAM,ON
    77
    Thanks, I hate to throw out bad info.
    It just appeared to give me a fresh blank chart that started to populate when I restarted the scanner.
    I'll have to check out the reset later.
  10. #30
    Sep 2017
    736
    It doesnt reset your charts fuel trim it resets the LTFTs in the pcm that it learned over time
  11. #31
    Jun 2011
    MARKHAM,ON
    77
    Quote Originally Posted by anniversaryss View Post
    Thanks.
  12. #32
    Jun 2011
    MARKHAM,ON
    77
    OK.
    Changes made and trims reset (properly this time) before logging.
    I think it looks good, but I'm no expert as you all know.
    Tell me what you all think, please.
  13. #33
    Jun 2011
    MARKHAM,ON
    77
    No comments? What's next?
    Will these numbers change after turning the MAF back on?
  14. #34
    Jun 2011
    MARKHAM,ON
    77
    I answered my own question.
    Reset the MAF and proceeded to log huge LTFT's.
    Apparently, my intake hose is leaking. The numbers told me to search for the problem.
  15. #35
    Jun 2011
    MARKHAM,ON
    77
    I wasn't happy with the leaking intake tube, so I made up a solid aluminum tube with zero leaks and same results with MAF reinstated.
    High L & STFT's and no intake leak.
    Should I be looking at a bad MAF sensor or do I now need to do some different tuning for the MAF?
  16. #36
    Oct 2018
    Ontario Canada
    42
    I'm running a similar setup in a 99 camaro with T56. 5.3 with flat tops, 243 heads, ls1 intake and injectors. LS2 cam from a corvette. Started with the 99 camaro ECM stock program and have tuned VE and MAF to 0 to -5 LTFT in most cells, runs really well. If you think my VE or MAF info will help let me know.
  17. #37
    Jun 2011
    MARKHAM,ON
    77
    Quote Originally Posted by KDS View Post
    Thanks.
    I wouldn't mind seeing the tune.
  18. #38
    Tuner K Rob's Avatar
    Apr 2021
    Oklahoma City, OK
    88
    good stuff here - trying to get my trims in check as well
  19. #39
    Jun 2011
    MARKHAM,ON
    77
    Quote Originally Posted by K Rob View Post
    How you enjoying the learning curve?
    Be careful with spark advance if you change the tune. I developed piston slap after going a bit too extreme.
    Or perhaps the 5.3 gets piston slap commonly? Don't know.
  20. #40
    Arizona
    482
    How you enjoying the learning curve? .
    what did you come up with with the high lt/fts after maf hooked up?
