Results 1 to 5 of 5
Thread: 8HP SLIP pattern colum lookup - HALF, FULL, HALF TO FULL, FULL TO HALF?
    8HP - Under the TCC clip pattern column lookup, table 30464, what do the HALF, FULL, HALF TO FULL, FULL TO HALF mean?
    If I had to take an uneducated guess which it is. Dynamic state map is fluid pressure monitoring statechange ie load state change? So say pressure is half its lowest load full its max half to full is the transition to max and full to half is the transition out. This transmission is fully customizable and as you can see with dodge programing at least in the hellcats that they have mapped its dumbed down and hardly used.
    So say ramping up they use one map and ramping down its one map. Then after max it changes with gears not really though but its mapped per gear then and cruising its maped per gear.
    These descriptions should be updated. Its engine state.
    Half = MDS active, half engine mode
    Full = MDS inactive, full engine
    If its not broke, just give it time.
    Well that's simple enough.
    Quote Originally Posted by Steven@HPTuners View Post
    Thanks!
