Results 1 to 3 of 3
Thread: supercharge trouble code p 012c and p 1101
    Jun 2016
    6
    problem with the codes p 012c and p 1101, not able to erase them with hp tuner know what is the problem ??
    corvette zr1 2009
    head and cam 102 throttle 20 psi E85
    thanks
    7,643
    This may not be related, but I have found a few codes that the changes will not 'stick' on when done the way that works for everything else. After saving & re-opening the file after changes, the DTC options are still what they were before. The fix is, make your changes, then CLOSE all open windows/tabs/whatever/everything inside the main Editor window, THEN click 'save' (or 'save as...'). Re-open, verify changes saved correctly.
    Jun 2016
    6
