Results 1 to 9 of 9
Thread: Can I remove the Rev Hang from 5.7L HEMI RAM?
    May 2008
    Texas
    97
    Can I remove the Rev Hang from my 5.7L HEMI RAM?
    Is "Rev Hang" the right terminology I should be using?
    Thanks,
    Scott
    Turbo'd S10
    Jul 2017
    33
    What year model is it bud. If by rev hang you mean the lazy shifts than yes. It can be tuned out. Depends on what trans you have for the process. Lot of good posts in the transmission forum for help.
    May 2008
    Texas
    97
    Quote Originally Posted by luciddeath View Post
    Sorry, 2014 RAM 1500 with 5.7L HEMI and 8-Speed.
    I'm not talking about shifts. The ZF shifts great. I'm talking about when your rev the engine and it /slowly/ decreases the RPMs.
    Thanks,
    Scott
    Turbo'd S10
    Jul 2017
    33
    I got you, I would post the tune up so people can chime in bud.
    May 2018
    I have had luck with decreasing PT spark in the low aircharge areas, will lead to surging if you go too far.
    May 2008
    Texas
    97
    I will work on pulling it down. It's the factory tune, though.
    Thanks,
    Scott
    Turbo'd S10
    Tuner coanan's Avatar
    Mar 2009
    S. Florida
    163
    Quote Originally Posted by thehemi View Post
    Thanks,
    Scott
    I'd look for vacuum leaks with a can of brake and parts cleaner, (flamable type) eng with rev if you hit the leak with it.
    2013 Chrysler 300S, 6.4 BGE with 6.4 SRT cam, AIT 18% OD pulley, E-force with 2.75 pulley, fastman 84+4 mm throttle body, 1 7/8 kooks long tubes w/hi-flow cats, Magnaflow Cat-back, FTI 2800 stall, Trans built by Hellraiser, Dings Racing valve body and tune, Getrag 3.73, Walbro 400LPH, DW 65# inj. LG aluminum rad. Dual SRT fans. 4 piston Brembo upgrade. Mopar Stage one springs.
    May 2008
    Texas
    97
    Quote Originally Posted by coanan View Post
    No, it's not a vacuum leak, it's the tune. Sounds like an emissions thing. I think it's most annoying with manual transmissions.
    https://www.carthrottle.com/post/rev...heads-hate-it/
    Turbo'd S10
    Mar 2018
    Illinois
    348
    When I was data logging via a trinity, I would often see throttle hang.
    https://www.challengertalk.com/forum...3&d=1518629940
    Unlike the chevy guys we don't have a pedal follower mode or at least one that is mapped.
    https://www.youtube.com/watch?v=MxnnFDpy2-4
    There are things in FI applications that can create more throttle hang but in NA applications I have not seen anyone successfully get rid of it completely.
    https://forum.hptuners.com/showthrea...l=1#post365545
