Results 1 to 18 of 18
Thread: Can I remove the Rev Hang from 5.7L HEMI RAM?
    May 2008
    Texas
    119
    Can I remove the Rev Hang from my 5.7L HEMI RAM?
    Is "Rev Hang" the right terminology I should be using?
    Thanks,
    Scott
    What year model is it bud. If by rev hang you mean the lazy shifts than yes. It can be tuned out. Depends on what trans you have for the process. Lot of good posts in the transmission forum for help.
    May 2008
    Texas
    119
    Quote Originally Posted by luciddeath View Post
    Sorry, 2014 RAM 1500 with 5.7L HEMI and 8-Speed.
    I'm not talking about shifts. The ZF shifts great. I'm talking about when your rev the engine and it /slowly/ decreases the RPMs.
    Thanks,
    Scott
    I got you, I would post the tune up so people can chime in bud.
    May 2018
    3
    I have had luck with decreasing PT spark in the low aircharge areas, will lead to surging if you go too far.
    May 2008
    Texas
    119
    I will work on pulling it down. It's the factory tune, though.
    Thanks,
    Scott
    Mar 2009
    S. Florida
    582
    Quote Originally Posted by thehemi View Post
    Thanks,
    Scott
    I'd look for vacuum leaks with a can of brake and parts cleaner, (flamable type) eng with rev if you hit the leak with it.
    May 2008
    Texas
    119
    Quote Originally Posted by coanan View Post
    No, it's not a vacuum leak, it's the tune. Sounds like an emissions thing. I think it's most annoying with manual transmissions.
    https://www.carthrottle.com/post/rev...heads-hate-it/
    Mar 2018
    Illinois
    873
    When I was data logging via a trinity, I would often see throttle hang.
    https://www.challengertalk.com/forum...3&d=1518629940
    Unlike the chevy guys we don't have a pedal follower mode or at least one that is mapped.
    https://www.youtube.com/watch?v=MxnnFDpy2-4
    There are things in FI applications that can create more throttle hang but in NA applications I have not seen anyone successfully get rid of it completely.
    https://forum.hptuners.com/showthrea...l=1#post365545
    Advanced Tuner MAIDENCR's Avatar
    Sep 2018
    Quebec,canada
    208
    Someone have a way to remove this stupid rev hang??
    Yes. The trick is going to be your torque model friction table. Let me screen shot one i did for a tsp stage 4 that had some rev hang with some minor tweaks you can get it golden
    So being that this vehicle didn't have a Minimum airflow table, I needed to adjust the friction table in order to keep it idling till i could verify with a afr gauge.. you all know the NN vehicle's ve table is junk when you put a giant cam in.. so anyways here is the stock and modified version to relieve the throttle hang.
    Attachment 93799Attachment 93800
    Mar 2018
    Illinois
    873
    I think OP is refering to the slow throttle down to idle like others have asked previously.
    https://forum.hptuners.com/showthread.php?80661-hemi-idle-lag-after-rev-help&p=584367#post584367
    That's exacty why i used negative values in there.. this vehicle had throttle hang when you would step on it.. now it doesn't.
    Of course you wouldn't need to add value to the low end, just put in lower values around 0 or some negative like i did to help it drop quick.
    In park if I gave it gas it would rev high and hold. Now it drops much better.
    Mar 2018
    Illinois
    873
    In the other post you stated the transient fuel decel tables could remedy this...or is adjusting friction a better alternative?
    818
    Have you tried logging commanded idle during the rev hang?
    I never adjusted transient fuel decel tables. I was refering to the torque model for that but for a idle issue someone had.. just stating that it would change it not remedy. I wouldn't touch those at all.
