Results 1 to 16 of 16
Thread: Injector data for Injector dynamics Ford Coyote/copperhead plaform
    Doing a tune for a 2012 mustang GT with Boss Intake Manifold, Vortech V3 3.6" pulley, Injector Dynamics ID1000 injectors, and JMS BAP, now when putting in the parameters for the ID1000s is it a straight copy and paste from the data sheets or do the values need to be modified for use in HPTuners? Fuel system is a standard return-less system.
    Thanks!
    Sean
    Originally posted in VCMEditor forum meant to post here apologies!
    Jul 2017
    529
    Most values are inverted, you'll need to flip them somehow, or type them in manually.
    I wish they were copy & paste
    That's not so bad i just wanted to make sure i don't need to alter the values since the car is boosted and has a BAP, i'm fine inputting the tables manually
    Sep 2010
    872
    The data is in their sheets but inverted, I usually type them out manually at least once, then I can copy them from that file going forward when ever someone has the same injectors. Keep in mind you want to use the stock fuel system values, not the 39 or return style data
    Mar 2010
    New Orleans, LA
    630
    stock is return style not return less
    Sep 2010
    872
    Quote Originally Posted by decipha View Post
    Coyotes are all return-less fuel systems from factory. Pressure is controlled by a small pressure relief valve in the hat that cranks open at 58psi
    Mar 2010
    New Orleans, LA
    630
    What you just described is a return style system. The regulator is mounted in the tank.
    Sep 2017
    Toronto, Canada
    40
    Coyotes are all returnless systems. They only have one fuel line to the engine. There is no return line back to the tank. Fuel pressure is regulated through the FPDM (Fuel Pump Driver Module), which is an electrical device designed to keep the desired pressure at the injectors and controls the power sent to the fuel pump.
    Sep 2017
    Toronto, Canada
    40
    lol no, that's corvette/GM stuff your talking about. That is a return style system but Ford's are set up differently.
    Mar 2010
    New Orleans, LA
    630
    the stock coyote fuel system is a RETURN STYLE SYSTEM.
    The regulator is mounted in the fuel tank.
    The FPDM is only used to reduce voltage at low loads as to not heat up fuel excessively as per emissions requirements and common sense.
    There is no fuel rail pressure sensor to regulate pump voltage for a returnless setup as would be required.
    If yall do not understand how the most basic of fuel systems function such as that on the coyote or any other vehicle then you have absolutely no business at all trying to tune anything.
    decipha @ EFIDynoTuning
    http://www.efidynotuning.com/
    Sep 2010
    872
    The 11+ Coyotes are mechanical returnless systems
    The pressure relief in the tank is not a regulator, it will do nothing to "regulate" the pressure, it is there to crank open when pressure exceeds ~58psi, the ECM send your voltage to the FPDM who then sends it to the pump, it will flow all the fuel it's capable of flowing at that voltage.
    Mar 2010
    New Orleans, LA
    630
    mechanical returnless = return with the regulator mounted in the tank
    What you describe makes absolutely no sense at all. Please explain to me how it can run less than 58psi ? Common sense should tell you that a defined fuel pressure is required. Since the ecu has no way of knowing that how could it possibly function?
    Advanced Tuner Witt's Avatar
    Pittsburgh, PA
    380
    It's two speed mechanical returnless. You seem to be under the impression that the only true returnless fuel system is an electronically regulated/turbine pump assembly. Mechanical returnless, there is no return line external to the fuel pump assembly which is what makes it returnless.
    Mechanical returnless is Ford's definition of the system.
    Apr 2018
    605
    2011+ Mustang 5.0s come stock with returnless style fuel system. Everything else stated by others is correct. No fuel is returned to the tank. 58psi. Two speeds (idle/load). People convert them to return style systems with 600+ rwhp applications (which is maybe all that you have dealt with?)
    Since you made that comment quoted above, does this mean you are retiring from tuning? lol :P
    Knock Retard is the reduction or prevention of knock by lowering ignition timing:
    (+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
    (--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
    __________________________________________________ ________
    2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
    Don't fix it if it ain't broken | Maximum effort gets maximum results
    Oct 2016
    Poland
    1,742
    But he's right - you are mixing things.
    Jan 2013
    Hawaii
    2,101
    stock is returnless.
    The fuel flow comes from being the unknown in the ratio relationship of the target lambda and airflow. Rail Pressure is inferred from fuel flow.
    If fuel returned to the tank, the fuel flow to the rails would not be reliable and the FPDM would not have any way of deriving more than a high and low duty cycle that used the relief all the time. Stock the 58PSI relief valve should only open on rare occasions, not constantly.
    Go to a return style defeats all this logic based on airflow and fuel flow. You should be using a 1:1 MAP referenced regulator to keep the difference between your manifold and rail pressure constant so your injectors flow at a single constant rate. Hence all the 1"s in the multiplier v pressure tables and the inferred rail pressure data becoming meaning less. I would call the difference base pressure, but ID's data seems to refer to base as the difference plus 14.7 or 1 standard atmosphere(which varies all around the world and different elevations). So their data isn't based in an absolute scale.
    You can do boost only reference in turbo and centri. setups, but you would need to use the stock style data with multipliers for different pressures and get the inferred rail pressure tables reflecting the true numbers. In short its a ton of work monitoring external sensors and adjusting, with double checking you are not throwing the trims off. Its also flawed if you are not using a pipe and known good MAF curve.
