Results 1 to 5 of 5
Thread: no power enrchment
    Jun 2018
    8
    no power enrchment
    2016 6.2 in a rock bouncer, cam and ported heads. previously tuned by a shop, we swapped to a e92 out of a 2014 5.3 truck to get rid of the throttle hang issue in the 2016's. I don't know what I'm missing but can't get it to command PE. can anybody help me with this?
    Mar 2010
    Texas Hill Country
    3,299
    without looking at the files, I will guess Peak Torque is maxed out or raised too high to meet the PE Tq criteria.
    13,564
    His peak torque is about double of stock.
    Dec 2011
    San Antonio, TX
    319
    set peak torque management table back to stock then bump 10-15% or so. Next, Lower enable torque under power enrichment. Should get you fixed up.
    JTC Performance - Authorized HP Tuners Reseller
    Remote performance tuning
    Jun 2018
    8
    changed peak torque table to 30% over the stock 5.3 and pe now works. It's strange that it worked this way on the 2016 ecm as we copy and pasted from that tune. this is my first go at the gen5 just trying to help a friend out. The throttle hang on the 2016 in a rock bouncer was just downright dangerous. thank you guys
