Car runs well mostly, idle is solid but for some reason when I give the car a very small amount of throttle like inching up my driveway (slight incline) the throttle position will drop from its idle position to around 6.7% and cause the engine to stall.
Mods are in my sig, Car has a NW102 throttle body with no hole drilled.
Trying to work out if there is a setting that controls the minimum throttle position when the pedal is in control.
Attached is a log where I was delibately stalling it, the problem is very repeatable and I dont think its related to Base Running Airflow as the airflow drops well below the settings in that table.
Tune also attached.
