Maye I'm just overthinking this, but I'm interested to know if I can use the sole wideband analog linear output wire and run that to both my wideband gauge input AND hptuners input?
I've been using a LC-2 wideband since it has TWO analog outputs, but I'm fed up with it. It sucks. I've been faithful to it for years because of the two outputs, but I need to try something else. It is not reliable and the sensors keep failing.
This is for a permanent install. All the other wideband controllers I see for sale only have one analog linear output and one simulated narrowband output (not sure if I can use that for my gauge).
