Results 1 to 6 of 6
Thread: setting up Holley 554-136 (500 psi) sensor in scanner help
    Feb 2008
    11
    i am trying to setup this sensor in the scanner for logging trans line pressure. can anyone help me out on what the transform function numbers should be. sensor has a linear output range of .5 - 4.5 and im using the 5 volt power wire from the AC pressure sensor.
    Feb 2008
    11
    Any help would be appreciated
    Sep 2017
    3
    Did you ever get this figured out?
    I think using .009 and Zero would work correctly.
    -Greg
    2009 Maverick Silver G8 GXP M6 - 586hp
    Engine Mods: TVS 2300 Magnacharger ARH 1 7/8" long tubes with catted x-pipe
    Drivetrain Mods: Ram Dual Disc Clutch
    Suspension Mods: Pedders/Wretched basic drag pack - BMR trailing arms
    Misc Mods: Jamesbiz Catch can - GRRRR8 Heater hose relo kit
    Jan 2021
    Did this ever get figured out I am looking to setup the same sensor?
    Dec 2014
    30
    I am using the same switch to monitor transmission pressure and am going to plug the .009 and zero into the user defined pid for the prolinkj #2 input and I will let you know what I get. Its logging the voltage so
