Results 1 to 3 of 3
Thread: 2012 Avalanche stock tune file
    Aug 2009
    Naples, FL
    339
    Hoping someone has a stock file for this truck. Not one in the repository, and I need to check the stock throttle tables.
    I have a truck here for a tune that keeps throwing p0606, and the tune in it was messed with pretty drastically before I got my hands on it. I've fixed p0606 before with stock throttle tables, so I want to see if that fixes it before exploring other options.
    13,564
    If it's any help. A 2013 Avalanche file uses the same values as my previous 2012 Silverado.
    A 2012 Avalanche is going to run the same throttle body and settings too.
    I've spent a little time in the past just browsing files within similar year ranges to see if anything were ever different. Often all the vehicles like the Tahoe/Suburban/yukon/avalanche trucks all run the same information if the computers were within a few year span of each other and they had the same engine/trans combo.
    Aug 2009
    Naples, FL
    339
    13 file was minutely different and still tripped the code. Ended up stopping by a dealership today and pulling a read off a stock truck. Problem solved
