Results 1 to 3 of 3
Thread: 2016 6.2 vats issue
    Aug 2015
    8
    2016 6.2 vats issue
    having trouble with 2016 6.2 swap. changed the OS to a 2014 dual vat OS as told still does not start. will only run when starter fluid is used. So vats are not letting injectors fire. file is attached. this is our first gen 5 swap and customer needs truck back ASAP and im stumped. have tuned over 30 gen 3 & 4 ecu with no issue.
    file is attached . all help apricated ! both file attached 2014 file is donar OS flashed to the 2016 file & ecu.
    Last edited by T203MPH; 06-24-2019 at 07:08 PM. Reason: current file loaded in ecu
    13,559
    VATS is still enabled in that file.
    Did you set them to disable and do a write entire using a different file?
    Aug 2015
    8
    can any one help?? is it not possible to swap those to OS ? what is the VATS fix for the 2016 ECU ?
