Results 1 to 8 of 8
Thread: E38 2bar SD hack
    Sep 2013
    45
    E38 2bar SD hack
    Hello everyone! I'm looking for some feedback on a wild idea I have had.
    - Currently running moded a 2 bar SD on supercharged ls3
    Needing to hack the load. At first I was going to try the half ifr half VE but that won't help with the fuel resolution when we change pullies and shoot for 30psi.
    Could I double the map scaling and half the VE to achieve double the VE map? I'm sure there will be other fueling changes to bring the injection back to normal.
    Is this to much hacking or a decent work around?
    Thanks for any feedback.
    Oct 2013
    211
    What are you trying to accomplish?
    Sep 2013
    45
    Quote Originally Posted by ZincGT View Post
    I'm trying to get the fuel map resolution to be able to tune over 255kpa.
    Feb 2015
    Perth, Australia
    974
    you can tune fueling off the 255 line in the VE table and with a rising rate boost referenced reg is shouldn't be too far off.
    you can alter the map sensor scaling so it reads less than actual manifold pressure to the scale of 255kpa is 30psi boost. then recal the entire VE table to suit, accept less resolution for driveability, cruise and idle. the VE values still need to be reasonable within range or it will effect spark resolution in a negative way.
    tune with a MAF
    Jan 2014
    Waldorf MD
    774
    Quote Originally Posted by 240sxpooter View Post
    Exactly how much boost are you trying to run?
    Daily Driver= 2003 BMW 330xi
    Weekend Cruiser= 2009 Pontiac G8 GT (Vararam, TSP LS3 N/A Stage 1, OBX, CTS-V converter, MagnaFlows w/ J-Pipes, 160 t-stat)
    Project Car= 1991 Chevrolet Camaro RS (LQ4 w/ Gen 4 Rods, LS3 heads, turbo...)
    Truck= 2007 Chevy Silverado 1500 LT LY5 4x4
    Aug 2009
    Calibrating
    3,373
    Since you are supercharged and boost is linear with RPM could keep it simple and Mod te PE table for more fuel past its 256kpa limit.. most likely only have to do past 5k RPMs
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Sep 2013
    45
    Quote Originally Posted by Ben Charles View Post
    Didn't think of that! Thanks guys
    Sep 2013
    45
    Quote Originally Posted by jaydubb71 View Post
    30psi
