Results 1 to 6 of 6
Thread: Falls out of closed loop
    2006 Z06, pretty big cam and headers, car will go into closed loop and then come back out of closed loop for a bit and then back in. Sometimes it will fall out several times before staying in closed loop for the rest of the drive. What?s causing this? I?m assuming the o2s aren?t hot enough but how does the pcm know? O2s are oscillating fine when it falls out, typically cruising under light load is when it goes into open loop. Are there parameters i can change to help it stay in closed loop?
    If you look at about the halfway point of this log, you can see it in open loop and switch back and forth a few times. Car was warmed up already at this point as well. Thanks!
    ST 3.hpt
    ST 3 d1.hpl
    Aug 2014
    Central, LA
    737
    Post tune?
    Jan 2014
    Waldorf MD
    774
    Post tune and a log
    Daily Driver= 2003 BMW 330xi
    Weekend Cruiser= 2009 Pontiac G8 GT (Vararam, TSP LS3 N/A Stage 1, OBX, CTS-V converter, MagnaFlows w/ J-Pipes, 160 t-stat)
    Project Car= 1991 Chevrolet Camaro RS (LQ4 w/ Gen 4 Rods, LS3 heads, turbo...)
    Truck= 2007 Chevy Silverado 1500 LT LY5 4x4
    Tune and log posted in first post, thanks!
    13,564
    You didn't disable the catalyst test and the post o2 sensor test.
    The computer is going into a test mode, it will pull it self out of closed loop doing this. You can even watch as your commanded AFR goes from 14.68 to like 15.9, then down to 13.6 and back to stoich/closed loop.
    Do this and your problem should stop forever.
    Thank you very much!!! Greatly appreciated!!!!!
