Results 1 to 10 of 10
Thread: 2012 Caprice L77 stage 1 TSP cam
    Oct 2018
    17
    I?m looking for guidance on a tune for the caprice with this cam. So far I?ve gotten just the idle to stick and looking for guidance as far as to getting the power out of the cam along with a decent lope.
    13,559
    Read about tuning the MAF and VVE with a wideband o2 sensor.
    Don't even think about power or lope until everything outside of power enrichment is fixed. Once fueling is spot on for part throttle, medium throttle and wide open throttle, then trying to optimize spark and power can be looked into.
    Same thing with idle and "lope". Fueling has to be fixed first so you are aren't working against yourself.
    Oct 2018
    17
    You have any pointers on where I can find more info on how to tune the MAF and VVE? Only issue is I don?t have a wideband o2 sensor
    Dec 2011
    San Antonio, TX
    319
    There's TONS of threads about MAF and VVE tuning if you do some searching.
    JTC Performance - Authorized HP Tuners Reseller
    Remote performance tuning
    Feb 2015
    Perth, Australia
    974
    attach file
    Feb 2015
    Perth, Australia
    974
    attach your tune
    Feb 2015
    Perth, Australia
    974
    ant senator final 386rwhp.hpt
    see attached for LS3 auto and mild cam file.
    its in 2bar SD though so you'll have to invert the VE table data if you use it for the VVE.
    without a wideband you can use STFT to tune cruise/ light throttle. its not ideal but provides an indication.
    ideally you need a wide band. set up a good scanner config. you want to disable closed loop and put it in full time open loop. you want to tune it MAF only and gather the fuel data and edit your MAF frequency table from the logs. Then disable MAF and put it in MAF fail and use the AFR data to tune the VVE.
    then turn the MAF back on set it to dynamic calibration and enable closed loop again
    Oct 2018
    17
    Heres my current tune
    Oct 2018
    17
    and most recent log
