Anybody every hook up a Dakota digital gear indicator gs 2000 to a 400 trans so 0411 pcm knows when truck is in PRNDL? Right now on scanner it?s showing in 2nd gear, I had a bench tune on pcm to remove VATS etc and transmission data removed since I?m not using the electronic trans. Was told pcm needs to know what gear truck is end so stalling won?t occur during deceleratings? If so what pin do I use at pcm? I?m getting a hp tuner In a few days, planning ahead of time for more $$$$$$$$ on this swap. 84 C10 swb 5.3 bored .30mm over 598/602 cam headers
