Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 97
Thread: 2009 lsa cadillac after dyno tune? Criuse tuning help
  1. #61
    Jul 2019
    JAMESTOWN, ND
    54
    Quote Originally Posted by jsllc View Post
    No way your VVE should look like this.Attachment 91431
    I hope mine didn't show up like that? It looks nothing like that in my tune file, or at least how it shows up
  2. #62
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    That is from your tune. At least the one posted.
    2012 ZL1 - Maggie Heartbeat, Port & Polish Heads, Custom Cam, Custom rotating assembly, steel sleeved LS9, No NOS and No water meth. 16psi
    810rwhp and 820rwtq 91 Octane 6400 rpm
    948rwhp and 951rwtq 105 Octane 6400 rpm
    999rwhp and 997rwtq on 60% Ethanol 6400 rpm
  3. #63
    Jul 2019
    JAMESTOWN, ND
    54
    how does that work? I shows up smooth on my computer.. How do I screen shot it from HP on my screen?
  4. #64
    Jul 2019
    JAMESTOWN, ND
    54
    try this
  5. #65
    Jul 2019
    JAMESTOWN, ND
    54
    latest adjustments
  6. #66
    Jul 2019
    JAMESTOWN, ND
    54
    I really need help at this. Guess I don't fully understand it yet. Thought I had read up on how to set up tuning files but obvious that its not going as planned. Any pointers are appreciated greatly
  7. #67
    Sep 2015
    Bozeman, MT
    701
    You are only extending to 100kpa not even sea-level. No boost. The one I showed went to 255kpa.
  8. #68
    Jul 2019
    JAMESTOWN, ND
    54
    You are only extending to 100kpa not even sea-level. No boost. The one I showed wend to 255kpa.
    For whatever reason it shows up that way in my tune
  9. #69
    Aug 2018
    294
    Quote Originally Posted by Dzz88 View Post
    You can click the axis in VVE editor and change it.
  10. #70
    Jul 2019
    JAMESTOWN, ND
    54
    think I got it this time. changed the row axis to read to 200kpa
  11. #71
    Jul 2019
    JAMESTOWN, ND
    54
    new table, all screwed up...
  12. #72
    Feb 2018
    830
    It isn't all screwed up...in my experience, when you extended the axis hptuners just follows the trend of what your current VVE table is so what you can do is just bring up those areas that are dive bombing up to the rest of the table...at least for a starting point. Besides that really big dips is occurring at a very low rpm and a very high cylinder kpa so your car may very well not even see that area of the VVE table
  13. #73
    Jul 2019
    JAMESTOWN, ND
    54
    this is my base, again lol!
  14. #74
    Sep 2015
    Bozeman, MT
    701
    Better,
    So you understand you are saying with this image that your engine is more efficient at 6500 rpm under most manifold pressure conditions than at equivalent 3800 rpm location. Your engine efficiency usually matches torque as a general rule.
  15. #75
    Jul 2019
    JAMESTOWN, ND
    54
    I'm just trying to smooth it out and go from there. I thought I was getting an understanding about what this table does, but you got me...
    So if I were to lower the 6k area it would be better?
  16. #76
    Sep 2015
    Bozeman, MT
    701
    Not saying you should do anything. Every engine is different. Many things go into to this. VE is used in later engines because unlike SD it is designed to compensate for factors other than just manifold pressure. Here is a start.
    https://www.onallcylinders.com/2017/05/11/volumetric-efficiency-and-what-it-means-to-performance/
  17. #77
    Jul 2019
    JAMESTOWN, ND
    54
    Thank you helping me BTW! I would guess my table is a lot different than what you have. Im at sea level and super hot right now. It a really bad time to be messing with all this stuff but its so far off part throttle. More boost lower rpms is killin me. Basically when car is in normal shift mode (auto) more noticed in am, cooler air, car goes lean... simple not simple. At least not for me, YET!
  18. #78
    Sep 2015
    Bozeman, MT
    701
    With in inputs your ECM has VE table should not be any different for elevation, temp and other things. That is the beauty of VE over SD. The only input and calc missing is humidity. So no your table and mine will be close.
    Our differences will be created by the efficiency of the motor (ability to pump air and combust fuel). Things like piston design, head design and porting, exhaust design and blower are the difference makers. All are highly modified on many cars including my ZL1.
  19. #79
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    474
    Checking from Vac... Glad you mentioned the morning vs afternoon. I see the same thing. It can swing 5-10% from morning to afternoon. Doesn't make any sense to me. You would think hotter air would cause a leaner mixture.
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
  20. #80
    Feb 2018
    830
    Quote Originally Posted by PGA2B View Post
    Hotter air is less dense than cooler air. So there are less air molecules per unit volume in hotter air. If your tune is spot in in cooler weather I'm willing to bet your fuel trims will be pulling fuel out when its 90-100 deg. outside while in CL
