Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 97
Thread: 2009 lsa cadillac after dyno tune? Criuse tuning help
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    476
    Is your tune remote, street, or dyno?
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    If anyone is going to really help you they will need a complete build list. Without it all just guessing.
    2012 ZL1 - Maggie Heartbeat, Port & Polish Heads, Custom Cam, Custom rotating assembly, steel sleeved LS9, No NOS and No water meth. 16psi
    810rwhp and 820rwtq 91 Octane 6400 rpm
    948rwhp and 951rwtq 105 Octane 6400 rpm
    999rwhp and 997rwtq on 60% Ethanol 6400 rpm
    Jul 2019
    JAMESTOWN, ND
    54
    Quote Originally Posted by PGA2B View Post
    Dyno. Was hoping to get some street time tuning but it was a loaded dyno... accurate only so much. Just trying to work out some spots that feel concerning.. don't show detonation, but are not right. I daily the car and want it to be better..
    Nov 2004
    St. Louis, MO
    476
    I totally understand. I have street tuned mine and will get it on the dyno someday. Have a MPS pulley system and cooling mods to go in but need injectors so waiting on that day... Wife is NOT mod friendly...
    I run a blended tune and am working on some fueling issues with transitions at part throttle.
    Sep 2015
    Bozeman, MT
    701
    No mods. You cannot just say 1150 injectors. Means nothing. Your whole tune changes with these. Like saying changed cam. Means nothing. Not picking on you just trying to get you the right help.
    Here is an example. These cams require different tunes and have different results. I have ran all of them in my ZL1. Injectors are the same. Looked at yours. Was trying to make sure that the cal was correct for what you bought.
    Intake
    Exhaust
    Duration .006
    288
    306
    Duration .050
    233
    251
    Valve Lift @ 1.7
    .607
    .614
    Lobe Separation
    120
    Intake Center Line
    115
    Camshaft Advance
    5
    Intake
    Exhaust
    Duration .006
    285
    309
    Duration .050
    235
    252
    Valve Lift @ 1.7
    .621
    .595
    Lobe Separation
    119
    Intake Center Line
    114
    Camshaft Advance
    5
    Intake
    Exhaust
    Duration .006
    281
    289
    Duration .050
    227
    236
    Lobe Lift
    .370
    .353
    Valve Lift @ 1.7
    .629
    .600
    Lobe Separation
    118
    Intake Center Line
    114
    Camshaft Advance
    4
    Intake
    Exhaust
    Duration .006
    265
    297
    Duration .050
    215
    247
    Lobe Lift
    .370
    .386
    Valve Lift @ 1.7
    .629
    .656
    Lobe Separation
    121
    Intake Center Line
    121
    Camshaft Advance
    0
  6. #26
    Jul 2019
    JAMESTOWN, ND
    54
    Quote Originally Posted by jsllc View Post
    No mods. You cannot just say 1150 injectors. Means nothing. You whole tune changes with these. Like say changed cam. Means nothing. Not picking on you just trying to get get you the right help.
    Intake
    Exhaust
    Duration .006
    288
    306
    Duration .050
    233
    251
    Valve Lift @ 1.7
    .607
    .614
    Lobe Separation
    120
    Intake Center Line
    115
    Camshaft Advance
    5
    Intake
    Exhaust
    Duration .006
    285
    309
    Duration .050
    235
    252
    Valve Lift @ 1.7
    .621
    .595
    Lobe Separation
    119
    Intake Center Line
    114
    Camshaft Advance
    5
    [FONT="] [/FONT]
    [FONT="]Intake[/FONT]
    [FONT="]Exhaust[/FONT]
    [FONT="]Duration .006[/FONT]
    [FONT="]281[/FONT]
    [FONT="]289[/FONT]
    [FONT="]Duration .050[/FONT]
    [FONT="]227[/FONT]
    [FONT="]236[/FONT]
    [FONT="]Lobe Lift[/FONT]
    [FONT="].370[/FONT]
    [FONT="].353[/FONT]
    [FONT="]Valve Lift @ 1.7[/FONT]
    [FONT="].629[/FONT]
    [FONT="].600[/FONT]
    [FONT="] [/FONT]
    [FONT="] [/FONT]
    [FONT="] [/FONT]
    [FONT="]Lobe Separation[/FONT]
    [FONT="]118[/FONT]
    [FONT="] [/FONT]
    [FONT="]Intake Center Line[/FONT]
    [FONT="]114[/FONT]
    [FONT="] [/FONT]
    [FONT="]Camshaft Advance[/FONT]
    [FONT="]4[/FONT]
    [FONT="] [/FONT]
    [FONT="] [/FONT]
    [FONT="]265[/FONT]
    [FONT="]297[/FONT]
    [FONT="]215[/FONT]
    [FONT="]247[/FONT]
    [FONT="].370[/FONT]
    [FONT="].386[/FONT]
    [FONT="].629[/FONT]
    [FONT="].656[/FONT]
    [FONT="] [/FONT]
    [FONT="] [/FONT]
    [FONT="] [/FONT]
    [FONT="]121[/FONT]
    [FONT="] [/FONT]
    [FONT="]121[/FONT]
    [FONT="] [/FONT]
    [FONT="]0[/FONT]
    So my injectors are going to be a problem... Started with ID850 then had them worked to 1150cc..... No data, I know. Impossible. Stock cam that was in the car... I get what your saying. I'm starting to think I may have to buy injectors...
  7. #27
    Jul 2019
    JAMESTOWN, ND
    54
    Mods list.. 2.38 upper, porter snout and 90mm tb, full texas speed exhaust, spark plugs, the mutt injectors.. id850cc worked to 1150cc, flex fuel, heat X with pump and underhood tank. Mighty Mouse can, Normal bolt ons
  8. #28
    Nov 2004
    St. Louis, MO
    476
    Did you get a spec sheet with the injectors? And who did the rework on them?
  9. #29
    Jul 2019
    JAMESTOWN, ND
    54
    AUS injection in Tempe. I'm pretty sure you can download spec sheets online for the original injector... I think the tuner did that and changed them accordingly... Just a guess. He did mention he was going at them blindly...
  10. #30
    Nov 2004
    St. Louis, MO
    476
    Oh great...
  11. #31
    Aug 2018
    295
    Yeah, I'd say get a good set of injectors in there with known data, and you should be able to get it driving the way you want it. With the rest of your mods, there is no reason it shouldn't drive perfectly with VVE, MAF, O2 sensor, flex fuel data, and all injector data (including tip temp) being correct.
  12. #32
    Jul 2019
    JAMESTOWN, ND
    54
    Quote Originally Posted by RobZL1 View Post
    I was worried this might be the answer...
    I never compared any injector data to what is there now.. Could be a mess. I'm not up to speed on that yet.
  13. #33
    Aug 2018
    295
    Probably possible to get it right with the current injectors but without sending them to get flowed and characterized it is a guessing game in my opinion. Plus, if the set isn't matched, there's nothing much you can do about it.
    This is just my opinion, of course. Someone more experienced should chime in before you take my advice as the final answer.
  14. #34
    Nov 2004
    St. Louis, MO
    476
    He already said they started as ID850's before they were worked.
  15. #35
    Aug 2018
    295
    My only point is they aren't necessarily characterized anymore, unless you are saying all other 850 data will be the same except flow rate.
  16. #36
    Nov 2004
    St. Louis, MO
    476
    No idea if anything changed but it probably did. Surprised they didn't come with specs from the shop that did them.
  17. #37
    Jul 2019
    JAMESTOWN, ND
    54
    I hAVE SOME FLOW DATA IS ABOUT ALL
  18. #38
    Jul 2019
    JAMESTOWN, ND
    54
    So your saying I could try it? Enter data from ID and see what happens? I looked at a few charts and found what I think is correct to try
  19. #39
    Sep 2015
    Bozeman, MT
    701
    Injector data is everything to getting your car to run consistently. Changes in voltage, pulse duration, min pulse and pressure all are variables that cannot be guessed. They have to be known to get the car to be predictable. I have used both FIC and ID. Injector data on either is accurate. Computers (ECM) are shit multipliers. Little in equals a lot out. Same is true of all the other items varied from stock. Always know the details of the changes.
  20. #40
    Sep 2015
    Bozeman, MT
    701
    The other thing to remember on VVE. It is not SD or VE. What your see is a visual representation of the results of a formula. It has infinite salability within each zone. Zone edges are almost impossible to get perfect and variations between cells cannot be as dramatic as true cell based tables. It is meant as MAF smoother with predictive values on lower ranges and backup to MAF failure. To use it for more than that is asking for trouble.
