Hey adjustment i made on my 2016 scat are no longer wokring when i try them on the 2019 for example, adjusting fueling under PE aircharge, i would adjust my wot fueling under there and it would show on my wideband accordingly. that doesn't seem to work on the 2019.
also for timing on my 2016 i would only adjust "WOT Base" and then scan n log the car which the changes would be there..The 2019 i can input whatever timing values i wanted there it will still only show the stock timing in a log.
i always left NN turned on as well
car mostly stock some bolts ons
also where is the throttle adjustments, to make the throttle more sensitive ?
