SO?.. I swapped a 6.0 lq9 out of a single cab into a s10 that has heads, cam, upgrade that was already tuned and was running good. upon the swap I decided to go to a tbss intake and a 92mm throttle body. the original tune was for a 78mm tb and stock truck intake. I thought that it should at least start up but no idle. instead I am having this p0335 issue and have ran continuity test on the wires and changed the crank position sensor as well. the crank relearn doesn't seem to be working but all the truck will do is act like its going to start then kill itself. vats are set to none. I am really new to the tuning world and im lost at this point because ive done everything I know to do help would be much appreciated!!!!
Put the scanner on and watch rpm while cranking if it stays at zero whole time odds are you have bad crank sensor but also check 5v ref and ground theres always some wiring fun on swaps
