Results 1 to 5 of 5
Thread: 2014 Silverado 5.3 Flex fuel sensor delete
    Jul 2019
    5
    In the process of getting the new HP Tuner setup for my '14 Silverado. I was wondering if I can see if the sensor is working or what the issue is before I have to just delete it ? I dont plan on using E85. I read some where I can delete it as well as the DOD. I have more questions of course but this is a start.
    Dec 2011
    Amarillo, TX
    250
    You can disable flex fuel with the flip of a switch, but I'm not really sure why you'd want to instead of just fixing the issue if there is one.
    What are you having a problem with?
    JTC Performance - Authorized HP Tuners Reseller
    Performance Tuning in the Texas Panhandle
    Jul 2019
    5
    It shows a code P0178 and have changed the sensor with a AC Delco replacement and the code still shows..... Wasnt sure if before I deleted it if the HP Tuner would show any type of data to show its reading the sensor or if its just a defective issue with the replacement part. also have a p0186 (Flex fuel temp sensor) and a P06DD code showing up..... Also I dont care for the feature of the flex fuel with the crappy fuel mileage I am getting.
    Aug 2009
    Calibrating
    2,211
    Could disable it and set stoich across the board to 14.10 and just run normal gas
    Email Tunes, PM me for more info
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jul 2015
    Poland (Europe)
    156
    Quote Originally Posted by psychoracing View Post
    you can only see alcohol % in fuel in Scanner. Also there are two kinds of Flex sensors, one is physical and "second one" is only math parameter. Both give same result of alcohol % in fuel. I always disable them cause we do not have this fuel here in Poland (Europe) and FLEX causes alot of issues when running LPG/CNG.
    best regards
