Results 1 to 12 of 12
Thread: 2006 36lbs injectors from 2009 2013 to 2006 6.0
    Wanting to swap out the injectors of my 06 with some 36 lbs of the newer model gym. Anyone have the injectors information for them?
    Thanks in advance
    Dec 2011
    San Antonio, TX
    319
    Do some searching. There's a gen4 to gen3 conversion spreadsheet on here somewhere.
    JTC Performance - Authorized HP Tuners Reseller
    Remote performance tuning
    13,565
    This.
    So i just copy the ls3 data?
    13,565
    No, follow the instructions.
    You have to input the GEN 4 injector data, then that will convert it to the GEN 3 injector data you need.
    Find all the tables that the spreadsheet asks for and it will convert the data for you.
    LS1 to LS3 is just what the file is called and the style of injector. You can see how the labels are different because the generation of computers are different.
    Cool... thanks...
    for some reason I can not copy and paste the info to excel. anyone have a file for 36lbs injectors pn12613411. gen4 to gen 3.
    thanks
    Mar 2016
    35
    I?ve tried using this also but the tables in the injector flow and the table is the gen 4 injector data is different. How do you fix that?
    Oct 2012
    gadsden al
    170
    what about the nuty 06 zo6 7.0 that show -80kpa to 80 kpa for flow.
    Sep 2017
    736
    This worked fine for me. I had to click "enable editing" otherwise it wouldn't paste onto xcel.
    If you cant get it ill do it later when I have time.
    1997 30th SS. Torqhead 24x, TFS heads, 223/235 cam, 4l80e, S60 D1SC 14psi
    Nov 2018
    47
    This.
    I used your converter to convert the 12613412 flex fuel injectors to a gen 3. With the flex fuel vehicle the labels are not the same as a ls3. So I changed the labels then input the data. Did I do that right?
    7,627
    Quote Originally Posted by Garyg View Post
    I posted a file in your thread that you can just copy and paste from. There are only a few very minor differences in the table layout between E40 and P01/P59.
