Results 1 to 12 of 12
Thread: Download boot loader request time out
    Aug 2010
    215
    I just tried to flash my car as I normally do, now I cant flash it, and my car won't start!!!
    Please help asap!! I emailed support! I am stranded miles away from my house!!!!
    Sep 2002
    Chicago, IL
    6,395
    Can you describe the vehicle you're trying to tune?
    Sometimes this can be caused by:
    - Wiring issue
    - Low battery voltage
    - Another OBD device that's connected
    - Aftermarket head unit
    We got this guy Not Sure, ...
    Aug 2010
    215
    My 2004 Z06 Corvette
    I removed fuses #5 and #9 from the footwell location.
    And removed #16 and #23 from under the hood. Left these unplugged for 10 minutes and plugged them back in.
    I left #5 (radio fuse) unplugged, and I was able to flash it.
    I've flashed it many times and never had this problem until I updated to the latest version. Not sure of the cause.
    28,264
    Considering the age of the vehicle I would lean towards a battery or wiring related issue.
    Aug 2010
    215
    Battery is two years old. I can give it a good charging and see if it goes away.
    I might also put the stock radio back in, as it is a Pioneer unit.
    28,264
    If that doesn't do the trick we suggest using a bench harness.
    Aug 2010
    215
    Not sure what you mean by 'bench harness'. Can you please clarify?
    Aug 2010
    215
    Never mind. Just did a quick Google. I don't have a bench harness setup, so I'm hoping charging the battery works.
    Jan 2019
    3
    Quote Originally Posted by SVT_Z06 View Post
    I have the same issue ever since I downloaded the new software update 4.4.2. If you un-check the "use high speed" box it will work. Is there a bug in the new update?
    28,264
    Quote Originally Posted by camaro1LE View Post
    Not that we are aware of.
    Aug 2016
    943
    I have seen GEN3 with aftermarket radios mess up a tune install as the original radio was on the network with other modules...so if the aftermarket is not wired right... Of course the weird part is that you have been able to tune it many times before... Maybe just a low battery.
    On the other hand I had a "time-out" on a 2018 Raptor today...nervous for a few moments but it went through on the next try.
    This worked for me ! unchecked high speed
