I have an 07 trailblazer SS
I need the injector data for a 2007 z06 ls3 oem injectors. The TBSS has the e67 pcm.
If anyone can help I would appreciate it.
I see the data for these on other pcms but not the e67.
2007 Trailblazer SS
Pacesetter long tubes/magnaflow duals/electric water pump/electric fans/fast lxrt/ported tb/ 4" CAI/as hood/
1999 CAMARO SS- LS2 1 7/8" LTs|BIGCAM|S2Heads|FTRA|UD Pulley|TRU DUALS|LCAs & LCARBs|panhard bar|BMR ADJ T-Arm|racetronix fuel pump|FAST102/102 Mcleod Adj MC|HINSON SHIFTER|S2 T56|4.56s|RAII|K&N|LID|Monster 4/electric water pump/micro edge/lnc2000/qa1s/nx plate/qa1 drag bar/12 bolt/4.11 gears/3.5 ds
E38 injector stuff is all in the same format, as far as I can see.
The only table that doesn't correlate is Flow Rate Mult vs Volts as the two use different axis values, but both tables are a flat 1.000 all the way across so who cares.
Just download the Chevrolet Performance LS3 file from the repository. It uses the E67 and has the info you are looking for.
LINK
2009 Maverick Silver G8 GXP M6 - 586hp
Engine Mods: TVS 2300 Magnacharger ARH 1 7/8" long tubes with catted x-pipe
Drivetrain Mods: Ram Dual Disc Clutch
Suspension Mods: Pedders/Wretched basic drag pack - BMR trailing arms
Misc Mods: Jamesbiz Catch can - GRRRR8 Heater hose relo kit
