I am running into an issue with a car that refuses to start. Here are the mods
2015 Mustang GT MT82
Kooks Long Tubes
2018 Intake Manifold w/ IMRC's locked out
Comp NSR Cams
JLT CAI
Stock Throttle Body
Ford Racing 60lb Injectors
Currently on 91oct
The car came to me with a mail order tune for the JLT and exhaust. The owner of the car had lost his handheld, so I just pulled that file out, and I am assuming the MAf curve is at least close for the JLT. All I changed was the injector data, the intake manifold volume, and turned off the IMRC's. The car will start for a few seconds, then die. 'Spark Source' is "Torque Control", and 'Throttle Angle Source" says "FMEM - Pedal Follower", and the wrench light is on the dash. There are no codes.
I would assume that the car should at least start and idle without touching anything in the VCT tables, so I could at least get the MAF dialed in. Do I need to make some adjustments to the torque tables just to get it going? What doe FMEM mean?
