Results 1 to 11 of 11
Thread: Trans Turbine RPM Spike, RPM Limit
    May 2015
    1,908
    I trying to figure out what to change in my TCM tune to eliminate a Trans Turbine RPM spike on my shifts that causes me to tap the rev limiter, close the throttle and cut fuel. You can see the engine rpms stay in check through the shift, but as soon as it appears the trans is completing the shift, the trans turbine rpms sky rocket to 7,000+ rpms. Thoughts?
    This is a Paramount Super Pro trans, 2800 stall, Ding's Valve Body, behind a 4.5L Whipple setup with a 426ci motor (around 900whp currently).
    Whipple Tune6 3-4 Shift.hpl
    816
    It sounds like you are describing shift flare.
    May 2015
    1,908
    Yes. But not showing in the engine RPM, only in trans RPM
    816
    Is one pid (RPM) polling at a faster rate?
    That doesn't make sense to me otherwise.
    May 2015
    1,908
    Ah ha, you are correct! clearly can see its slower polling.
    But regardless, back to the original question, shift is commanded at 6500 rpms, I can see it commanding a shift starting right around 6500, but flares to 6900-7000rpms before it completes the shift. Any suggestions on fixes to get it to shift earlier before the rev limit?
    816
    No I don't think I know how to fix it. It's possible that something is hurt in the trans and it can't "grab" the next gear as quickly as it should. Clutch or band or something in the system that applies them.
    Does it do it on every gear change, or just a specific up-shift? Does it get worse in higher gears or at higher road speeds?
    I'm trying to figure out the 8spd transmissions right now and also about to yank out and go through the 727 in my wife's Trailduster. Haven't looked at NAG1s.
    May 2015
    1,908
    Issue I have with it being mechanical is it acts the same at half the horsepower. Doesn't seem power related, i.e. mechanically related to the clutches slipping. Guessing has something to do with the handoff and pressure applied as the outgoing clutch pack releases, maybe its releasing before its supposed to.
    816
    Did you recently change the valve body?
    May 2015
    1,908
    No, been running a Ding's VB since trans was new. That said I do have the original Paramount valve body I could switch in, just the drivability is pretty horrid outside of WOT. Like getting hit with a sledge hammer every shift.
    Jun 2010
    30
    Quote Originally Posted by 06300CSRT8 View Post
    You should log the "downshift" PID. I am experiencing an interesting issue on my 06 Turbo SRT8 Jeep. Around 5800 RPM the TCM is commanding downshift until about 6200 RPM then it flips to upshift and by that time it is too late and I hit the engine rev limit and it cuts throttle exactly like what you saw here (3 years ago I know)...
    Log(s) here.... If I run 4psi I get no downshift command, with 6psi the TCM commands downshift every time like clock work.
    R8_Schams_E70_4psi_2-3shift(1).hpl
    R3_Schams_E85_0-120mph_7psi.hpl
    Jun 2010
    30
    Interesting to note for others who are searching the forums in the future. My no shift issue in 2-3 happened on my EGS52 TCM, when I switched to a Karma TCM EGS53 yesterday the no shift issue went away. It don't know if that was due to a limitation in EGS52 or the Karma TCM tune. Long story short, if you have a power added on an 06 SRT8 Jeep I would upgrade to an EGS53 TCM at a minimum or buy a Karma TCM.
    2006 Jeep Grand Cherokee SRT8 / 76mm turbo / E85 / Dings VB (Stock longblock)
    10.1@132
