Results 1 to 9 of 9
Thread: Tightening up 2-3 shift, 6F50/6R80
    Oct 2011
    27
    Can anyone give some advice on tightening up the 2-3 shift at WOT on a 6F50, same stategy as the 6R80?
    Part throttle is great, but at higher/WOT throttle it is a pretty slow shift.
    Looks like the adaptive learning may have gotten caught up.
    Jul 2018
    7
    what is the shift pressure in the higher trqe area I am only familiar with the 6r80
    Oct 2011
    27
    Quote Originally Posted by Blueford5 View Post
    You will have to lower the adaptive slip times, otherwise it will soften the shift over time
    Advanced Tuner metroplex's Avatar
    Apr 2013
    Detroit, MI
    797
    Your Explorer doesn't have much torque, so you can try to increase the shift pressure at WOT starting around 200 ft-lb. What you have would work fine with the Explorer Sport or any EcoBoost V6.
    Oct 2011
    27
    Quote Originally Posted by metroplex View Post
    After a bit of aggressive driving it actually "fixed" itself. I guess adaptive learned and made some adjustments on that side.
    Any tips on a downshift issue from 6th? It wont downshift until I get pretty far into the throttle and then it goes to 4th. Would like it to go to 5th with a little less throttle input rather than the hard drop to 4th at a higher throttle position.
    Apr 2013
    Detroit, MI
    797
    You will have to adjust the shift schedules. Ford did not program the sport mode schedules correctly on the Explorer and PIU.
    Tuner skylinedan's Avatar
    Sep 2019
    Toledo Ohio
    56
    ^^^ That's no lie, LOL. They're way off on the shift schedules up high, ive lowered mine quite a bit just to keep it from hanging out in gears to long after settle into a constant speed.
    Apr 2015
    25
    I know this is an older thread but I wanted to share my experience. I recently have been working on a ford escape with the 6f35 transmission and the 2-3 shift was miserable. I have not adjusted much but what I did was copy the 3->4 tables on ramp, adaptive, and clutch fill time and applied them to the 2->3 shift. Now I will say I haven't tried a WOT shift yet but it really helped out with half throttle shifting. I also haven't messed with shift pressure yet as I'm doing one thing at a time and learning a lot on the way.
    P.S on my Clutch fill time schedule between 2->3 and 3->4 I only adjusted the fill rates that were slower. The ones that were showing faster on the schedule I left alone.
