Results 1 to 6 of 6
Thread: Fuel cuts and g/cyl plummets at certain boost level in SD, but not in MAF mode?
    Baltimore, Md
    1,210
    What are the limits of boost you can RUN, vs what scanner reads (stops reporting MAP at 255 kPa), doesnt look like Maximum MAP limit has any affect on anything?
    Factory Stock 97 SS M6 13.51 @ 104.3 mph
    Stock Longblock LS1 w/ 233/238 P.S.I. Cam
    10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
    '99 TA trunk mounted 76mm 6 Liter
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    32psi and still winding out 5th on the highway somewhere
    Oct 2013
    211
    I pegged 255 at 5500 rpm on a centri blower setup, just made adjustments to the rpm side of the VE table.
    Baltimore, Md
    1,210
    Quote Originally Posted by ZincGT View Post
    What are you talking about?
    Oct 2013
    211
    Here is your question
    Quote Originally Posted by GrannySShifting View Post
    Here is your question with my answer
    What are the limits of boost you can RUN, vs what scanner reads (stops reporting MAP at 255 kPa), (The scanner does peg at 255kpa, on my setup it would peg 255 at 5500prm so to make fueling changes I adjusted my ve table in the 255kpa section but used the rpm axis to dial it in. My setup was making roughly 26psi.) doesnt look like Maximum MAP limit has any affect on anything?
    Baltimore, Md
    1,210
    It sounds like you are saying you made every VE table value 255kPa and above the same, and adjusted those values in each RPM column to get the air fuel you want one time on a dyno for example.
    Thats not really a great solution, because on a cold November day you might see 2psi more across the board it wont know about (would be fine if you left it fat in less dense air, we used to have to do stuff like that before multi bar MAPs etc)
    Its especially not a solution on a turbo car where boost will see 245 kPa, 260kPa, 280 kPa variably
    Oct 2013
    211
    Yes I agree, my a/f did very about .5 with weather however that wasn't your question at least from how I understood it. I was just trying to provide feedback on how I handled my situation with more then 255kpa. You could also scale back the map sensor settings so instead of being at 100kpa key on engine off you could try 80. Just a thought, I do this when I travel and race, match up the baro reading with what I have here in denver and it helps dial in my fuel table faster and allows me to "see" more overall boost.
