I am at a complete loss on this car. I need advise where to look and if this is even tune related at all. The car is a 2008 G8 GT. I wrote a Holden 6 speed OS because I ditched the 6l80 TCM then applied the 2.5 bar OS and speed density patch because the MAF is completely out of the picture
Engine: 408ci cast block (gen 3), hand ported ls3/l76 heads, BTR cam kit and stock LS3/L76 intake. Turbo is a FI billet T4 S480. FIC 1200's, twin 340 in tank pumps. Secondary is activated by a Hobbs switch at approximately 4lbs (verified).
Transmission: TH400 reverse manual VB and Cameron convertor
The issue is when MAP goes beyond 169-170ish kpa, the car sputters violently. It sounds exactly like RPM's are being limited except it seems to be more load related because I have achieved 6,000+ RPM in low gear while 2nd sees less than 5500 and high gear will stop around 5k. Whats odd to me is MAP pressure shows an increase while RPM falls and TPS stays steady. I thought spark was being blown out so I put new plugs in it and tightened my gap down. I thought maybe the wastegate controller was causing the issue ,despite arguing with myself this has to be spark or valve train related because the frequency is so high when the condition occurs, so I took the controller line off my WG and upped springs to 15 lbs. The AEM truboost shows a max of 14.7 psi across the entire log I am attaching. I will admit the tune is very rough. I have been chasing this issue for over a week and dedicated all my spare time to fixing this stupid issue. Thank you in advance!!
