Thread: 2008 cobolt security disable
    Aug 2018
    4
    Could use some input on disabling the security on a 08 cobolt with a 2.2. We are putting this on a dirt track in a 4cyl class. The cavaliers had a vats disable under system/general. On the Cobolt it a setting called starter diagnostics master enable. Would this be the same as Vats on the cavalier?
    8,344
    Click the OS tab. The VATS 1&2 are located there.
    You need to be in advanced view under the edit tab to see all tables. This change will require a write entire when VATS is under the OS tab.
    Aug 2018
    4
    Aug 2018
    4
    Thanks for the info never bothered to check there. Wanted to make sure I could disable before buying the credits.
