Results 1 to 20 of 27
Thread: AEM Wideband transform question
    Apr 2019
    Texas
    30
    I'm using an AEM 30-0300 wideband I've noticed that my wideband reads a little different (.5 to 1 point) than what HPtuners sees when using the proper transform ratio (V/.42105263)+7.3125. For instance my wideband gauge will say I'm at 14.2 and HPtuners says I'm at 15.1. I'm using the same formula that the manual states and what HPtuners has by default. I'm using AFR not lambda.
    I've changed the formula a little to more closely match what my wideband is actually showing me.(V/.45105263)+7.3125 (With in.2-.4 points now)
    Is this typical to have to manually adjust the formula for each wideband or do I just have a wonky one?
    I've done the resistor cal and free air cal with the same results.
    Thanks guys.
    05 Silverado Single Cab Long Bed
    LM7
    VS Racing 7875 12 PSI
    E85
    Snow Stage 2 Meth
    BTR Stage 2 Turbo Cam
    Built 4l80E
    Australia
    1,979
    u should leave the v/.42105263 as is but just change the +7.3125 to suit the voltage offset u must have that way it adds to correct the offset and not the calculation, what ever u are out by say .5 or 1 subtract that from the 7.3125 and it should dial it straight in
    Apr 2019
    Texas
    30
    Great ill give that a try tomorrow thanks for the reply!
    Waldorf MD
    774
    Quote Originally Posted by Ecobear86 View Post
    How did you get it to work?
    Daily Driver= 2003 BMW 330xi
    Oct 2017
    Boston
    75
    Hello,
    I am now having similar issue with the 30-0300 using its analog out to the MPVI Pro on my C6 Corvette...
    The gauge reads 14.67 AFR but the analog/HPtuners reads 14.1. I did change the offset to make it match up but then while logging on the street the analog/HPTuners is reporting much leaner than what the gauge says.
    Gauge says, for example, 11.5 but analog reports 12.5.
    AEM is sending me a replacement but I fear it's going to do the same thing. Anyone else hit this?
    Thanks,
    Pj
    Waldorf MD
    774
    I'm using the same WB but I'm using Lambda. No issues
    Oct 2017
    Boston
    75
    Thanks for the feedback....It is closer in lambda; gauge reports .99 while HPTuners reports .96 so, off by .3 instead of .6 with analog. Maybe a ground problem?
    Will post results with the replacement once I get it...
    Thanks,
    Pj
    Waldorf MD
    774
    Quote Originally Posted by pjs View Post
    Thanks,
    Pj
    No problem. Do you have the brown and white wires connected to your MPVI or MPVI2?
    Oct 2017
    Boston
    75
    Yep, brown and white to the MPVI Pro.
    Dec 2005
    604
    For the 30-0300 the brown wire is critical. If it is connected to ground, at the MVPI/ProLink, you can check the output with a voltmeter, between the white and brown wires, when the gauge reads ~14.7 at idle. The measured voltage should be very close to the range 3.00v-3.25v. If it is, the hardware is all working OK. And, the problem is in the conversion math.
    If you are using the MPVI2/ProLink, you should use the CAN data channels. And, avoid the math.
    Waldorf MD
    774
    Quote Originally Posted by dr.mike View Post
    CAN isn't available on the 30-0300.
    Dec 2005
    604
    It is, if you are using the MPVI2 Pro Feature Set / ProLink.
    Not the OBDII CAN, like the 30-0334. But, the native AEMNet CAN of the 30-0300 is available over the ProLink's CAN lines. This is, actually better than the 30-0334/OBDII method. And, is saves bandwidth on the OBDII CAN bus.
    I do it all the time
    Waldorf MD
    774
    Hmmmm. Ok. I may have to try this...
    Oct 2017
    Boston
    75
    FWIW....I got the replacement gauge today and it does the same thing. I figured it would. Analog reading is way off even when I change to offset so that reading matches up but only matches at stoich. Once it goes WOT/rich, readings go off.
    Will try using serial method but had to order serial-to-usb adapter. Hopefully that works else I guess I can try the AEMNet CAN thingy...
    Thanks,
    Pj
    Dec 2005
    604
    The AEMNet CAN data is orders of magnitude better than the serial data. If you can possibly use CAN, go that way.
    Oct 2017
    Boston
    75
    Looks like the 30-0300 does not come with an OBD2 connector. It has 2 CAN bus wires but not clear in AEM's manual how to use them with HPtuners or OBD2. I've been googling but no luck figuring out how to use it...
    Do I need to connect the 2 wires to an OBD2 connector somehow or do I have the wrong model of gauge?
    Thanks,
    Paul
    Oct 2017
    Boston
    75
    Some luck....Found an HPT thread that says you need to use a passthru connector to splice in the two wires.
    https://forum.hptuners.com/showthrea...d-beta-testers
    Does that seem reasonable?
    Thanks,
    Pj
    Dec 2005
    604
    No. The 30-0334 CAN connects to the OBDII port. The 30-0300 & 30-0310 CAN wires connect to the CANH and CANL wires of the ProLink.
    Oct 2017
    Boston
    75
    Thanks, So the CANH/CANL won't work with MPVI Pro? I don't have the MPVI2/ProLink...
    Dec 2005
    604
    Right. For the old MVPI PRO, you are limited to Analog or serial. UNLESS.... You have a post 2007 car. THEN, your 30-0300 can be re-flashed to 30-0334 firmware. And, THEN, you can connect it to the OBDII port. Just like a 30-0334.
