Results 1 to 3 of 3
Thread: P01 - 2 Bar Map Sensor - 12615136 - Tune settings ?
    Oct 2014
    41
    Hello,
    I'm kind of confused about what MAP settings to use, the sensor (12615136), is a Cobalt SS 2Bar sensor, so I would assume you would use the map settings from a Cobalt which is:
    Map Sensor Linear : 270.59 KPA
    Map Sensor Offset : -0.478 KPA
    Yet on the forums I read everyone recommends:
    Map Sensor Linear : 200KPA
    Map Sensor Offset : 8KPA
    So which one do I use? Also, yes the OS has been written for 2bar OS, I'm just doing research before continuing.
    Thanks.
    Jul 2012
    Florida
    1,454
    200/8 are the correct settings for that map sensor.
    2013 Silverado 5.3, 6L80k 8.8
    Oct 2014
    41
    Thanks, I guess the question now is, why would the default settings from the Cobalt not work ?
    Thanks again.
