Results 1 to 16 of 16
Thread: Trying to read 2018 Infiniti Q60S and getting a "x7F: Negative Response Code"
    May 2009
    454
    I am trying to read my 2018 Infiniti Q60 with 3.0 VR30 using SH_7253_131 and the other one and both are giving me the same error codes. "Reader upload request:x7F Negative response code"
    It says the operating system is 14GE6A.
    Any ideas?
    2018 Infiniti Q60s
    2004 350z/LS2: ERL 434ci, 11.8:1,TFS245cc,262/266@113+3,Fast102,NX 102 plate,60#injectors/return w/twin 255s
    Old setup: CNC'd317s, Fast 102, 228/228@114, PT88,83#injectors/full return system. 10.84@138
    Clinton MD
    422
    ***Watching this***
    Daily Driver= 1998 Pontiac Grand Prix GTP Coupe (3.4 pulley, SD Headers, SLP catback, FWI, 180 t-stat, hotwired FP, Autolite 103's, poly dogbone bushings, solid rubber engine and trans mounts, self tuned with HP Tuners)
    Weekend Cruiser= 2009 Pontiac G8 GT (Vararam, TSP LS3 N/A Stage 1, OBX, CTS-V converter, MagnaFlows w/ J-Pipes, 160 t-stat, self tuned with HP Tuners)
    Project Car= 1991 Chevrolet Camaro RS (On3 7875, LM7 build on hold)
    Truck= 1995 K1500 ECSB 5.0 5-speed (Dusty...)
    Dec 2011
    Amarillo, TX
    299
    Haven't tried reading an Infiniti, but when I get an x7f its either low system voltage or bad USB cable.
    JTC Performance - Authorized HP Tuners Reseller
    Performance Tuning in the Texas Panhandle
    May 2009
    454
    I updated to the beta software and now I am getting a "FAILED TO RETRIEVE FLASH DATA". I sent the infolog to HPT and am awaiting their response.
    2018 Infiniti Q60s
    0x7F error on Nissan is almost exclusively battery load too high (if it's not bad USB cable related). Need to make sure everything is turned off, these things are finnicky. No A/C, no headlights, no radio, etc.
    As for the failed to retrieve flash data, it's because we don't have your file stored on the server. The read of your vehicle is an actual read of the calibration, and a "virtual" read of the OS section. If we don't have your file stored on our server we don't allow the read to finish. We have to purchase it and then create a definition, then you'll perform the read after all of that is done.
    Also the controller type for the VR30 is SH_7253_331, but on downloading latest beta (when it's ready, it isn't yet) it should auto-identify as that controller.
    May 2009
    454
    Quote Originally Posted by evan.s@hptuners View Post
    How will I know when its ready? -Mark
    2018 Infiniti Q60s
    I'll reply to your ticket when it's ready. I just wanted to post that publicly since there have been a couple tickets from confused people on this platform.
    May 2009
    454
    Thanks for all of the quick replies.
    2018 Infiniti Q60s
    May 2009
    454
    Will this have to be done before tuning every Nissan/Infiniti ECM?
    2018 Infiniti Q60s
    May 2009
    454
    Now I am getting a :Failed
    Controller init: not ready with newest beta.
    2018 Infiniti Q60s
    Quote Originally Posted by Snyper View Post
    Responded to your ticket but since it's posted here publicly: tuned with ecutek. They lock the read. Have to return to stock first.
    May 2009
    454
    I was able to put the ECM back to stock and successfully read the ECM.
    I notice that engine diag and the transmission tables are blank. Will those be available at a later date?
    2018 Infiniti Q60s
    Both are being worked on but there is no ETA
    Aug 2014
    6
    Any update on the ETA for engine diagnostic and Transmission tables?
    Quote Originally Posted by pax13gt View Post
    DTC lists have been added in, if you don't see them send in a support ticket with your OS ID. No ETA on trans stuff.
