Results 1 to 5 of 5
Thread: OLSD 3 bar minimum injector pulse
    P01 411 ecu, lq9, ID850's, turbo in a 69 C10. Pulse width will not drop below 2.5ms most of the time. If it does it drops straight down to 1.4ms then back up to 2.5. Nothing in between. Making it difficult to tune the VE table at idle and light cruise. I have the lower KPA cells in the VE table dropped way down with no change. Minimum pulsewidth is set to .122 per ID's data.
    Log 1.hpl
    _3bar_os_turbo.hpt
    13,565
    Cut the min fuel milligrams under the transient fuel tab in half. See what that does for you.
    Welp. That definitely did the trick. I actually went down a 1/4 of the stock value. Thanks!
    13,565
    Good deal.
    Somebody sticky that!!! Was loosing my mind.
