Results 1 to 17 of 17
Thread: 2018 ZL1- how do I turn off catalyst light off on cold starts?
    Jul 2007
    12
    I removed the cats and disabled COT, but I hate the sound of cold starts while the Cats are warming up. The combination of my exhaust and no cats makes it crazy loud. How do I disable the cat light off?
    Go to Engine, General, Catalyst.
    Raise the enable to 490 fahrenheit and disable to - 140 fahrenheit.
    Then, go to Engine diagnostics, Exhaust, Disable catalyst test.
    Jul 2007
    12
    I don't have that option in mine. Under engine and general there is only engine displacement options and that's it.
    Mar 2010
    Texas Hill Country
    3,299
    It's under Exhaust tab now
    Jul 2007
    12
    Quote Originally Posted by Higgs Boson View Post
    The only exhaust tab I have is under Engine Diag. There I have the Catalyst Test (which I can disable) but don't have anything else. I assume this is to disable the actual OBD testing of the cats, but not the initial warm up(light off). Correct?
    Where would that be?
    13,565
    Post the file..
    Jul 2007
    12
    I hope that works. I've never done this so please bare with me.
    Jul 2007
    12
    So I found it. I had to search for it in the parameter navigator and it's in a hidden folder called exhaust. This folder doesn't appear anywhere else for some reason. Really strange. Thanks all.
    Mar 2010
    Texas Hill Country
    3,299
    you are probably using Basic view. Change your setting to Advanced
    13,565
    He is right, it's not listed under the regular exhaust tab even in advanced view.
    If you look in the navigator there is an exhaust folder there that has it. Both the regular and beta version on my computer show it there. My beta is the latest as of today, so 4.4.4X.
    Jul 2007
    12
    Nope, I've tried both basic and advance. I can only see the Exhaust folder in the Parameter Navigator. Wired stuff.
    Worked like a charm though.
    Mar 2010
    Texas Hill Country
    3,299
    interesting
    bumping this up. Looks like this parameter is now totally removed from the latest versions.
    May 2003
    South FL
    1,369
    Been that way for anything past 4.10.6.
    [email protected]
    Owner/GM Calibrator
    Sep 2008
    7
    Has anyone found a work around for the parameters not being available anymore?
    May 2003
    South FL
    1,369
    You can try an older version, but some of the older versions won't open newer cars. Just have to try your luck. There is no work around other that what I've suggested.
    [email protected]
    Owner/GM Calibrator
