Results 1 to 6 of 6
Thread: how to check if pcm is already unlocked
    Got a charger hemi 2016 pursuit would that have an unlocked pcm already? How do I check if its unlocked already?
    816
    It wouldn't be unlocked unless someone sent it out for unlock.
    2015+ are all locked.
    Jun 2018
    Dubai
    62
    i also wonder if there is a way to know if it has unlocked pcm or locked one - for example if you bought a used car is there a way to know ?
    Jeep wrangler 2012 automatic, sprintex supercharger, 9lbs of boost, 4.5" lift, fox 2.5 internal bypass shocks, 4.88 gears, 37" tires,
    Ford Mustang Shelby gt350 2017, airraid air filter, jlt catch-can,
    Nov 2009
    All Around
    3,149
    you can always read the file, but try to write and it will either let you or not.
    Nov 2021
    25
    And can you check it without using credits?
    Mar 2021
    Pompano Beach FL
    263
    you will need credits, however they will still be active after unlock as long as you use the same pcm.
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
