Results 1 to 20 of 33
Thread: '18 3.5L Ecoboost with Turbo Upgrade, what am I missing?
    Jul 2019
    16
    Hey guys,
    Thanks ahead of time for any help.
    Truck; '18 F150 3.5L Ecoboost, turbo upgrade, FMIC, etc...
    I'm at ~19psi boost on the top end, but can't seem to get past it. Fuel is E30 mix. What limit am up against?
    Big thanks to those of you helping everyone on this forum.
    Log and Tune:
    F150_turbos_E30.hpt
    F150_turbos_E30.hpl
    Thanks!
    -Boost
    Quote Originally Posted by M5Boost View Post
    Hey guys,
    Log and Tune:
    F150_turbos_E30.hpt
    F150_turbos_E30.hpl
    Thanks!
    -Boost
    Can't see the tune from the PC I am using, but here are some from the Log file you've posted.
    You are hitting Cylinder Pressure limit for the timing ECM 50229)
    Also you are hitting the Injector Limit, might need to increase fuel rail pressure and Max Injection angel ECM 7719
    Jul 2019
    16
    Quote Originally Posted by mrshanab View Post
    Thanks for the quick reply. I have max inj angle set to 270 degrees. I?ll try adding rail pressure.
    How about blending more PI fueling? Can we log the low pressure injector DC?
    Thank you
    I have raised mine to 330 degrees, in my 2017 Raptor for reference
    Never touched the PI fueling, can not comment on that
    injector DC would be one PID that is not in relation to the low nor the high pressure ( I could be wrong though)
    Thank you
    Jul 2019
    16
    Ok great, I?ll try 330 degrees first. Thank you
    Jul 2019
    16
    So I set it to 330 and same result. I must still be missing something. Any ideas?
    JO-F150-E30-v5.hpl
    JO_F150_E30_v5.hpt
    JO-F150-E30-v5.hpl
    JO_F150_E30_v5.hpt
    Ok
    ECM 7310 to 2.0
    ECM 7306 to 2.0 the whole column
    ECM 44616 try and add 5 degrees to the 1.6 load point and beyond ( Trying to eliminate the Cylinder Pressure spark limit) You need to watch out for knock though!
    Keep in mind, we are trying to address the limiters first, not the boost.
    Jul 2019
    16
    Ok
    ECM 7310 to 2.0
    "injector DC would be one PID that is not in relation to the low nor the high pressure ( I could be wrong though)"
    I see 7310 is referred to as a "safety factor", but 7306 does refer to "DI Injector duty cycle". Though, both have a 2.00 value limit. I wonder how these are actually working. I will try changing those and report back, thanks.
    For spark, I was intentionally leaving it low until I get up to the torque request I'm looking for. However, does the comb. stab. spark limit also limit load? Or is it only affecting spark? Ign advance starts with your borderline, then works towards cylinder pressure limit based on learned knock right? Please correct me if I'm wrong.
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    613
    44616: Is a cap and is not learned. It is always there.
    Jul 2019
    16
    Quote Originally Posted by LastPlace View Post
    44616: is a cap and is not learned its always there
    Thanks. Understood. But as far as the ign adv strategy, does it adjust from borderline, and up to max of cyl pressure based on learned knock adjustment over time?
    Jul 2016
    613
    It goes from borderline (plus or minus adders) > MBT
    Whats learned is comes from Knock adaptive leaning tables (if you are using them)
    But if you reach 44616: it stops there...
    Jul 2019
    16
    Got it, OK thanks.
    Jul 2016
    613
    In some cases mbt for be less the all others...
    Jul 2019
    16
    Ok
    ECM 7310 to 2.0
    So that took care of the spark limit and injector limit. Thanks
    Last thing left: Torque Max Source - popcorn
    Log:
    JO-F150-E30-v5c.hpl
    Jul 2016
    613
    Log:
    JO-F150-E30-v5c.hpl
    What is that "Torque Max Source - popcorn" doing that you don't want?
    Jul 2019
    16
    What is that "Torque Max Source - popcorn" doing that you done want?
    Is it supposed to be torque max source = "full load limit (normal)" when there's no limits hit?
    Jul 2016
    613
    Its not closing your throttle.
    Jul 2019
    16
    Attachment 91650
    Is it normal for "engine brake torque" to be about 15-30lbft less than "ETC torque request" / "desired brake torque" throughout the pull?
    Jul 2016
    613
    That is a questions for a ford calibration engineer or someone like steven@hptuners
    I would be looking into why "actual's" are greater then your "desired's" around 5400rpm
    Also your turbos are spinning at a speed that will shorten their lifespan.
    Jul 2016
    613
    This thread is asking the same question your are about "popcorn" and in post #2 steven@hptuners explains what your seeing
    @Puggyberra in post #4 explains more about what you fixed yesterday
    https://forum.hptuners.com/showthread.php?69011-Torque-max-protection-source-Injector-limit&p=511942#post511942
