Results 1 to 4 of 4
Thread: 'Manual' vs 'Non-Electric Auto' Questions. For transmissions with no VSS signal.
    Aug 2018
    19
    A buddy did a 5.3L / TH350 swap into an older truck so I programmed a computer for it. I did a manual trans segment swap (same OS Camaro - T56) and all the other items I read on here to do as far as Abuse modes.
    I read that the transmission type drop-down didn't matter so I left it on 'Manual'.
    The engine ran but wouldn't rev-up. I changed the drop-down to 'non-electric auto' and everything worked fine (engine reved to 5200 rpm).
    My questions are:
    1. Was this likely caused by the manual segment swap looking for a VSS signal?
    2. If I did the same tune for an older manual trans, should I select 'non-electric auto' since there is no VSS , or will this cause a different issue?
    Thanks in advance.
    13,564
    I find that the problem can sometime be because you are starting with a automatic OS. Anytime I've used an OS that started life with a 4L60e/4L80e I've left the drop down as stock and disabled all the abuse and transmission related DTC's. Never had a problem doing it that way.
    It's possible it's looking for something else or things get funky when you change things around when dealing with an auto OS.
    Dec 2008
    on the Dyno
    1,825
    If it has an automatic transmission in it then you need to keep the automatic tune file. Reason: This gives you the option for better idle control IF you hookup the park/neutral safety switch to the PCM and set it as such. When you flash a manual tune the PN input and PN idle routines are ignored thus leaving you in the in-gear logic at all times.
    The speedo hookup has no bearing on this. Both automatics and manuals alike had speed sensors. I'd suggest hooking one of those up as well since it will also give the ability to dial in rolling idle routines like throttle cracker.
    I also wouldn't mess with the transmission drop down menus as they switch internal logic to stuff we don't have access to in the background. Depending on which OS and which vehicle the calibration is for will determine what that switch does.
    Located in Central Kentucky
    ShorTuning
    Apr 2022
    10
    [QUOTE=5FDP;578458]I find that the problem can sometime be because you are starting with a automatic OS. Anytime I've used an OS that started life with a 4L60e/4L80e I've left the drop down as stock and disabled all the abuse and transmission related DTC's. Never had a problem doing it that way.
