Originally Posted by
06300CSRT8
that cam will not idle at that low of RPM. I wouldn't try to idle it any lower than 800 or so. Raise your Low Idle rpm setting to 700 and make the rest of the idle set points be 800 or so. Make your lockpin VVT timing table match your part throttle timing table (at idle cam should be at lock pin), and smooth out your timing table left to right, you have a cliff from 14 degrees to like 20 degrees in a 300 rpm change.
Your Minimum spark is wrong, needs to be stock except wherever it was negative be 0 degrees. Your current table has a minimum of 14 in the idle area which isn't good and the rest is zero, it will need to pull timing below that if its over idling.
